Results 1 to 4 of 4
Thread: DPF on 3.6?
    Manly QLD
    DPF on 3.6?
    Hi Guys,
    Whats the chance my Aug 2007, Aus delivered 3.6TDv8 has DPF fitted?
    I was of the opinion that none in Aus had them. Currently going through the process to remap the EGR out and BAS have come back with "from the ECU info, your car has DPF - so......."
    I can't see a DPF (assume it will be right up near the turbo) - whats the chance it has the wrong engine firmware?
    Sep 2012
    Adelaide Hills
    Quote Originally Posted by harlie View Post
    Hi Guys,
    my 08 3.6TDv8 doesnt have it.
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    Mar 2007
    No DPF's on Australian L322's
    Laurie
    Manly QLD
    thanks Lads,
    had a look late last night with IIDTool, all the DPF readings are there but obviously there's no DPF
    NUMBER OF REGENS = 0
    DIST SINCE LAST SUCCESSFUL REGEN = 0KM
    NUMBER OF FAILED REGENS =0
    VOLUME OF SOOT = 0
    TOTAL VOLUME OF DPF = 0
    all the readings are either 0, 100 or 1024.
    Is it possible for someone to check their car with IIDTool - if all the DPF readings are active?
