Results 1 to 10 of 21
Thread: Lower ...and Upper control arms (high kms) ..what else?
    Mar 2010
    back in WA
    Morning,
    Well the D4 started to tell me the lower control arms need replacing via Morse Code ...again....as such, with 315,000kms what else to do because when I do drive it it does not feel that as good as use to (naturally).
    So do I do the upper control arms as well? what else - steering arm bushes? given we have 20kms+ of crappy gravel roads in any direction each day we (my wife that is) take the car out (and average black top for a 100kms+) I suspect most bushes will be tired.
    Appreciate any ideas. also views on OEM/Factory, etc arms/bushes etc. in looking at Britpart/LRDirect obviously a lot of variation in the price if replacing the whole lot...
    Nov 2015
    Black Rock
    Morning gotaflat,
    Jack up the car so that all four wheels are off the ground. Get a pry bar of some sort (a long tyre lever will do) and, starting with the front lower control arm bushes, pry between the chassis and the bush. Start at the front LCA bush as that will have the most movement and you can then see what you are looking for. Then work your way around the entire car. That will give you a good idea of what needs replacing.
    At that mileage, I'd replace each arm complete as necessary and personally I'd go genuine.
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Jun 2013
    Augusta WA
    Quote Originally Posted by gotaflat View Post
    Morning,
    KIT619O Optimal Front Upper Arms Set Discovery 3 Left & Right With Bolt Kits This is "Advanced Factors" in the UK their Mehle HD Lower control arm bushes or complete arms are a great ride.
    Nick
    MY09 D3 TDV6 Zermatt Silver
    MY02 TD5 Bonatti Grey (Sold)
    MY00 TD5 520K (Sold)
    Sep 2014
    Baldivis WA
    Upper arms unlikely to ever need replacing, can do top ball joints as separate item. LCAs are an achillies heel, the AF hd version with mehle bushes are top choice. Easier and cheaper to repkace the complete lca assy than muck around with rebushing etc. I would also suggest to check sway bar bushes and tie rods front and rear.
    Jul 2012
    Perth- South of the River
    Quote Originally Posted by Eric SDV6SE View Post
    The AF HD seem like a good option and are probably what I'd go for if doing complete arms. However, to say easier and cheaper is not entirely correct. A set of rear bushes are relative cheap (compared to complete arms) and using a bush removal kit, pressing them out and in with the arms on the car is reasonably simple and quick. Now, the caveat is of course ones willingness to order the parts and do the work. Easier and cheaper may be correct if paying someone to do the work.
    Gone 05 D3 ARB Front Kaymar Rear Winch E-Diff LRA Tank Dual Battery
    Current 2015 SDV6 SE. Tow Pro Mitch Hitch Llams C/motives 70ltr w/tank 2 x comp Traxide BMS-2 x Aux 150w Solar Uniden Engel ARB drawer F/Runner rack Light bar
    Jul 2013
    I've changed every single arm in my D3 during the course of my ownership due to flogged out bushes - LCA on the second set.
    Shane
    2005 D3 TDV6 loaded to the brim with 4 kids!
    http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
    Sep 2014
    Baldivis WA
    Quote Originally Posted by Dagilmo View Post
    Agreed, id be willing to do them myself as long as the tools are available.
    Mar 2011
    Balbarrup WA
    RE :replacing upper AND lower control arms
    My D3 has just logged up 500,000K, and so far I have fitted 4 sets of lower front control arms and nil need for upper control arms to be replaced (yet).
    Ii seems all the work is done by the lower front control arms.
    I have replaced 1 steering rack and recently 1 rack end rod.
    Nil replacement on rear end, but have been advised that 1 bush on a rod on the rear should be done ASAP as not helping with wheel alignment.
    Morning,
    Wow 500k klms..thats good going.
    Might have to add the D3 to the list of cars guaranteed to do a half million ks!
    May 2015
    batemans bay NSW
    Disco 10 years
    That front upper arm kit looks good. One thing to be aware of. The nylock nuts get screwed onto the bolts at the factory, then undone by you before installation, then screwed on again. This seems to remove their capability to stay tight. I had three of them on a VW control arm come loose and bolts fell out. Fortunately nobody hurt. Would suggest loctite or spring washers.
