Brake and Throttle Pedal at the same time doesn’t work!
The vehicle sees it as combatting features.
If you want a slow nudge, select Low Range and let it creep on the brake at idle.
 Wizard
						Subscriber
						Wizard
						SubscriberFeel like a numpty asking this one but was trying to delicately park in a tight spot against a gutter and every time I gave the car a nudge with the left foot on the brake it wasn't interested, just powered down.
Do I need to use a different mode? Can I not use Normal?
Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
Then 2010 D4 3.0 HSE 'James'
Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
Then 2010 D4 TDV6 'Jumbo' w traxide DBS
First love 2002 D2 TD5 'Disco Stu'
Thats why left foot brakers have issues with modern vehicles,as they unknowingly, sometimes drag the brake pedal.
I know a guy who bought a D4,quite a few years ago, and had all sorts of issues with it.While the dealer had it for a few days,the loan car started to have the same issues.
He was a left foot braker.Changed his driving style,never had the issue again.
 TopicToaster
						Subscriber
						TopicToaster
						SubscriberThe car flags an error event that you can pull with a diag tool every time it sees a brake and accelerator combined event. It’s considered a fault, not something one should do. Unless you’re a racing driver, I agree.
2007 Audi RS4 (B7)
Have to laugh about this. I mean the brake cancelling out the accelerator. You can just imagine all those ones and noughts trying to figure out what's going on, giving up and replying "computer says No"!
I suppose this means that the old Series technique of leaving the left foot on the brake for a little while after river crossings to dry out the drum brakes is well and truly consigned to history and the failing memory of us old farts. You learned this after your first river crossing where the exit was a steep bank. You'd try to stop, but your brakes would be useless and you'd simply slide back (well, not slide really as your wheels would happily be rolling unhindered) into the river. The transmission brake might grip, but there was always the danger that it could slew you sideways and you'd have even less control. It only took one experience for you to always keep going up, with your left foot on the brake, until you found a flat spot to stop.
Then cresting a steep track with, I swear, the last revolution of the motor. But I'm getting nostalgic. All those tracks that I conquered with skill, wheel placement, throttle control and brilliant driving I now cruise up in the D4 with barely a spill from the crystal champagne glass. Not sure the D4 even needs me there at all...
2013 D4 expedition equipped
1966 Army workshop trailer
 TopicToaster
						Subscriber
						TopicToaster
						Subscriber TopicToaster
						Subscriber
						TopicToaster
						SubscriberI don’t own a late model car...but drive hire car a lot.
I still keep to the age old method off
Right foot is for brake or accelerator
Left foot is for clutch.
Some hire cars have an electronic handbrake that disengages when you press the accelerator, this doesn’t feel like its being friendly to the brakes so I disengage manually.
