With LHS front door open push button on dash to lock all other doors and tailgate. Close LHF door and use key to lock the door.
If all actuators are working correctly and completely the vehicle will be locked.
Is it the same process as unlocking when your fob isn't working i.e. via the passenger side door handle? If so mine does not appear to lock manually.
2006 TDV6 Disco
Cheers, Dale
'The D3' - 2006 TDV6 HSE
Previously Enjoyed:
2000 D2 Td5 - plus!
That make sense thanks very much. I'm assuming this will not trip the alarm next time I manually open LHS front door as I haven't used the fob to lock?
2006 TDV6 Disco
