Results 1 to 2 of 2
Thread: land rover discover 2 front fog light relay
    Mar 2019
    Oberon
    Good morning One and All,
    I have recently ugraded the bull bar on my D2 and it comes with the fog lights included.
    I have gone to Landy Mechanic who has turn on the fog lights through the BCU
    I have a 99 disco 2 and have bought front fog light switch YUG102620 connected to the green wiring loom
    I have checked the fuses and they are ok
    I bought a 12v 40 amp relay some sites show a 5 pin relay others show a 4 pin relay
    does any one know what relay do I need, 4 pin/5 pin, resistor/no resistor 40amp Less/more
    just nothing seems to get them running.....
    head lights are on, no light on switch when I press button
    Jul 2014
    west of Transylvania
    Google out YWB10004L, this kind of relay was fitted from factory on '99 D2s(4 pin, 20A, no resistor). Anyway, swap your's with the horn relay(R13) and if the horns are working with that relay it means the problem is not that and you'll have to double check if the setting for fog lamps was really saved in the BCU or not.
