Results 1 to 10 of 12
Thread: GU TD42 twin oil filters.
    Sep 2010
    The Hills.
    152.79 MB
    I'm trying to help my son with his 2003 GU Patrol which did a head gasket. That's fine, but the car is converted from the 3.0l hand grenade to a TD42, probably from a GQ. This engine runs twin oil filters. Fine, not a bad idea. However, when I came to remove the filters ( head gasket, you change this stuff, right? ), the rear filter was empty, and showed no sign of oil ever being in it. The front filter was as you'd expect. Does anybody have Nissan experience and could tell me what's going on?
    I don't like mysteries when it comes to engines.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    NSW far north coast
    That's really odd, although it may just be the anti drain back valve not holding and the oil has drained back to the sump.
    This used to happen all the time to the TD42's and TD42T's I serviced, and pretty common in general for standard nitrile ADBV's to not hold.
    There were two versions of the twin filter setup.
    One ran two full flow filters, the other ran one full flow and one combination filter, which is part full flow and part bypass (ie. a high efficiency, low micron element) in the one can.
    The fitting for that one is a different size and style to the full flow filter fitting.
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by rick130 View Post
    Thanks. Both filters are Z115s. The strange thing to me is that the rear filter seems to have never seen oil, although I haven't actually dissected it.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Nov 2015
    Yass
    I had a GQ TD42 for twelve years and on every oil change both identical filters were full of oil.
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by jbe View Post
    Which is what I'd expect.., and why I asked. I was perplexed.
    Perhaps there's a blockage somewhere. OP seems fine, but I don't know what they usually run. Maybe I should remove the filter housing.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    NSW far north coast
    The Donaldson I mostly used wouldn't hold, it'd always drain back past the ADBV and so the filter had nothing in it when spun off.
    Genuine would hold fine.
    Sep 2010
    The Hills.
    152.79 MB
    Hmm. The ones fitted were Ryco. So are the new ones. I'll run it and then see.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    NSW far north coast
    John, from memory the filter pressure relief/bypass valve was in the aluminium housing they screw onto, not the filter, so check to see if that's not stuck open.
    Sep 2010
    The Hills.
    152.79 MB
    Thanks Rick. Does that mean that the PRV is in the housing as well? I’m asking only for the info.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by johntins View Post
    Whoops, reading this on my phone. Not used to that.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
