Results 1 to 10 of 24
Thread: Yikes....$$$$$$$$
    Dec 2008
    Victoria
    Yikes....$$$$$$$$
    I went into one of those chain type auto accessories/parts etc shops the other day. I needed a couple of new tyre valve caps...you know...just the plain old plastic jobbies. Found a packet of 4 and was stopped in my tracks. $14.95 for the pack of four. They stayed there!!
    Last year I needed a rated shackle (or 2). Bunnings was literally half the price of SuperCrap.
    Brisbane, Inner East.
    Quote Originally Posted by Grumbles View Post
    You pay for them? I thought you just picked up a few on your way through the supermarket car park. Many 4WD's have the spare tyre mounted at a convenient height.
    URSUSMAJOR
    Oct 2007
    Wantabadgery, N.S.W.
    Go to a tyre shop. They'll give you a handfull.
    Don.
    Jan 2017
    Geraldton WA
    I don't use them as I am forever airing up and down they are a PITA to replace all the time.
    4.6m Quintrex boat
    Back down the hill.
    They're also the primary seal. The valve is the secondary seal.
    Brisbane,some of the time.
    Metal ones are the best,they have a rubber seal and don't leak if the valve is leaking slightly.
    I generally find them on the ground around the air pump at garages,don't think i have ever bought one.
    Jan 2017
    Geraldton WA
    The primary is the Valve, The cap is there simply to keep the dirt, dust, mud out of the valve stem.
    Try pumping your tyre up without a valve in it and just rely on the cap to hold the air in there and you will soon realise that the valve IS the main seal
    Even my Missus knows that and she is definitely Not a motoring expert.
    4.6m Quintrex boat
    Back down the hill.
    Like you even your missus is wrong, unless you're smarter than the engineers from the Tyre & Rim Association.
    Most people, myself included, wrongly treat the valve as the primary seal. The cap is also important for keeping the valve contaminant and damage free. Only a fool would not use valve caps.
    Jan 2017
    Geraldton WA
    IF the rim and tyre association belive that those silly little plasic caps will hold the air in a 4WD tyre at 40psi (envision a truck tyre at 100psi+) or more without the valve doing its job then they are sadly deluded.
    YES i Agree that the caps do a great job of keeping the crap out of the valve stem BUT a tyre WILL stay inflated without them, Not so much without a valve fitted and relying on that ridicules bit of plastic to hold the air in there though.
    The VALVE IS the mechanism that seals the valve stem, The cap is simply a dust cover to keep the crap out of the valve stem and is NOT the Major component keeping the pressure in the tyre.
    As I air up and down on a regular basis ( at least twice a week) I am always aware of the tyre pressures on my 4wd's and I always ensure that the valve stem is clean Before I air up again.
    When is the last time you or many others here actually physically checked the tyre pressures on your cars/4WD's.
    The valve cap is a dust, dirt, mud "Cap" and nothing more.
    4.6m Quintrex boat
