Thread: Park Lights not Working
    Jul 2014
    Hobart, Tas
    Hi All,
    I have just noticed both my park lights don't work. I had an issue with a head light about 1 month ago and changed the bulb so had to disconnect the indicators and park lights to remove the trim, head light etc. Put all back together and headlights worked - I didn't check the parkers.
    Head lights (and spotties) are on a Traxide loom. Those and the indicators work.
    Any ideas?
    Sep 2014
    checked the fuse?
    I assume you only removed one side to fix the headlight?
    Jul 2014
    Hobart, Tas
    Quote Originally Posted by filcar View Post
    checked the fuse?
    Are park lights on their own fuse? I assumed they were on the same as the blinkers. I'll check that.
    Regarding removing one side, I changed both globes and kept the working globe as a spare.
    Jul 2014
    Hobart, Tas
    So I checked the fuses on the weekend and they are all working.
    I'm at a bit of a loss now. Anyone else had the both park lights stop working
    Gold Coast QLD
    Quote Originally Posted by 4xsama View Post
    Do you have 12v power at the plug on the back of the light fitting?
    D you have 12v on the prong when you remove the globe from it's housing?
    I had a brake / tail do a similar thing, it turned out to be corrosion in the plug
    from water ingress through a crack in the lense. The bulb was blown, but
    looked fine looking through the lense. I ended up replacing all of them with
    an LED kit.
    Cheers Ian
    1964, S2a SWB "Ralph"
    1977, S3 SWB "Smeg" (Gone)
    1996 D1 300tdi auto (Gone)
    1973 Rangie Classic (Gone)
    2012, 110 (Series 12) Puma "The Tardis"
    1962 109" Tray Back "Ernie"
    1998 D1 300tdi (Dizzy)
    2017 Kawasaki Versys 1000
    You must now cut down the tallest tree in the forest... With... A HERRING!!!!!
