Results 1 to 10 of 13
Thread: Discovery 3 - additional dual battery addition - unexpected!
    Dec 2011
    Adelaide
    142.79 MB
    At present I have a D3 4.0L ptrol, fitted with a traxide system, and the additional battery under the hood on the driver side.
    Today, I paid $10 on Gumtree and collected an unused Hardkorr battery box which looks like bloody good value for $10!!!!!!
    I now trying to figure out how to make the most of it.
    Any suggestions? (and "send it to me and I'll give you $10" doesn't count!!!)
    I've got the outlet from the Traxide in the rear of the truck, and that is where the Engel plugs in, plus any other goodies I want to add.
    I'm thinking of putting a battery in the box, and mounting it in the rear as an extra power supply - but do I need a DC-DC to keep it charged, or can I just plug the battery box into the rear Anderson plug from the Traxide install????
    I'm thinking there is room under the top of the box to mount a DC-DC unit, but do I need one???
    Any comments greatly appreciated.
    2012 L320 Range Rover Sport Fuji White
    REMLR 012
    No 5 Trailer ARN 177-295
    2006 Disco 3, 4L V6 Petrol SE Deceased Feb 26 2023
    SOLD Engineers Trailer - no id
    SOLD RAAF 231194 Perentie 110 GS - SIR ANGUS
    SOLD 4MP COY Series 3 FFR 30-209
    Adelaide - Torrens Park
    Quote Originally Posted by Aussie Jeepster View Post
    No. You don't.
    St Helena,Melbourne
    1.13 MB
    Just run another cable from the output side of the traxide controller to the extra battery, earth it and bobs your lbgtqyxz aunty.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    DiscoMick Guest
    X2
    Queensland
    Hi Jeepster, as the others have suggested, simply plug the Anderson plug at the rear, into your new battery box and job done.
    In this setup, all three batteries will act as one big battery and will charge together when the motor is running.
    PS, that’s a nice looking battery box.
    1.13 MB
    My guess is the battery needs to be an AGM to remain compatible with the rest of them?
    Rod
    D4 MY16 5 seat TDV6 - LLAMS, Custom Drawers, OL Bar, Toyo Open Country, GOE Rims, Lithium DBS, eDiff, OA Long Range Tank, GAP Tool, Tracklander rack, Mitch Hitch, TPMS & Safari Snorkel
    Queensland
    Quote Originally Posted by rocket rod View Post
    Any lead acid battery will be fine. Not just AGM.
    Be cause the alternator is the primary charging device, it can be an AGM, wet cell, Calcium/Calcium, gel and it can be a deep cycle or a cranking battery.
    ONE WORD OF CAUTION, Jeepster, from your photos and pictures of this battery box elsewhere, it does appear to be totally sealed.
    If this is the case, you could put some air holes in the box, both at the top and low Dow on the sides or ends.
    For safety reasons. Battery boxes MUST NOT BE TOTALLY SEALED.
    BTW, I can not find any info on the size of the circuit breaker, can you check it out?
    DiscoMick Guest
    Yes, don't use a lithium because that would require a DC-DC charger.
    Try to make the new battery the same type and size as the other second battery, so they will charge the same.
    Queensland
    Quote Originally Posted by DiscoMick View Post
    Hi Mick, because the primary charging source is the alternator, you can have any mix of different types of lead acid batteries and all will be charged properly.
    It is only when the primary charging source is a battery charger, a DC/DC device or a solar regulator, that the batteries should be of the same type.
    They can still be different sizes.
    NOTE, While not ideal, but if you know how to set up a DC/DC device or a battery charger or even a solar regulator, you can actually charge a mix of different types of lead acid batteries at the same time.
    Dec 2017
    wandin nth vic
    I see the box has a 50 amp charge plug that says VSR BUILT IN . Does this mean this battery wont receive charge until the other 2 batteries have a reasonable SOC?
