Results 1 to 10 of 16
Thread: Sound deadening a Defender
    Jun 2015
    DiscoMick Guest
    We put the Car Builders stuff in ours and it does help. Get the 4WD waterproof version so it doesn't get water logged and cause rust.
    Bracken Ridge, Qld
    In due course I'll be getting the car builders kit as well - so easy given they have all the necessary stuff, measured for the Defender 90, 110 or 130 (whichever you have), video instructionms etc and its an Aussie Business.
    Land Rover 110 Floor pan sound and insulation packs
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Apr 2019
    Quote Originally Posted by DiscoMick View Post
    Hi Mick
    I notice you reference the 4WD Waterproof product, I don’t see it listed on car builder website. Just wondering if you are thinking of another product?
    DiscoMick Guest
    No it was Car Builders. They had one described as 4WD because it was waterproof.
    I just checked the website and they've changed the way its presented. I assume the 4 x 4 packs are waterproof, but maybe you could ring them and check.
    Apr 2019
    I read three posts where you have mentioned it...I assumed you were across it.
    DiscoMick Guest
    That's how it was when I bought it a couple of years ago. I still have a box of it in the shed.
    The website has changed, and now shows classes of vehicles, but I assume the 4WD and ute categories would use the waterproof version.
    A call or email should confirm that.
    Apr 2012
    Whyalla, SA
    Quote Originally Posted by W&KO View Post
    Hi Mick
    Their normal product - not the felt/foam one - is waterproof.
    Apr 2019
    Hmm...carpet under lay is different to sound deadener, ya might want to clarify the product you refer to when posting.
    Have it all sorted not
    DiscoMick Guest
    This product is a sound deadener which is waterproof and is laid under carpet.
