Results 1 to 10 of 14
Thread: Radiator Outlet Temp Doesn't Change | 05 L322 4.4 M62
    Nov 2019
    Hi brains trust,
    When looking at live data from my IID Tool, the radiator outlet temp stays at 90deg constantly. As soon as the car is switched on it is at 90.
    I've just replaced the lower rad sensor to fix the below error, which fixed the code, however the issue of the 90 deg still remains! (see attached photos)
    0x47D Radiator Outlet temperature sensor fault
    Very strange! Anyone seen this before, or have some advice on where to start the troubleshooting steps? As above have completed the following:
    1. Change lower rad outlet sensor
    2. Visually checked connector
    3. Sprayed connector with contact cleaner
    One thing I did note, was that when I changed the sensor the coolant looked brown so ill be doing a quick rad flush over the weekend w/ a look to pulling the whole cooling system out and giving it a powerflush + checkup later on down the track..
    I went for a drive to Costco today which is about 40 min from my house, temps were holding as follows on the highway however these were lower than i normally see getting around town:
    Coolant: 105deg
    Rad Outlet: 90deg (broken)
    Gearbox Temp: 105deg
    Transfer Box Oil: 116deg (yikes?)
    Thanks!
    05 L322 Range Rover | BMW M62 4.4 | Cairns Blue
    07 Lexus GS450h | 2GR-FSE Hybrid | Blue Onyx Pearl
    I've never checked mine. If I remember, I'll check tomorrow.
    Nov 2019
    Will shoot the GAP guys an email if it is the same on yours.
    Nov 2019
    Hey Ron, did you get a chance to check?
    No, I haven't. If it stops raining, I'll go out and do it.
    I don't have the BT version so I may need my laptop connected to see live values, therefore I'll need to run an extension lead as the laptop battery will be flat.
    Mine's a little different to yours.
    My radiator coolant temp moved up and down a fair bit on a drive but the coolant temp pretty much sat at 90.0 deg C. It moved a small amount from 89.7 to 90.7 but soon came back to 90.0
    I'll check again tomorrow when the engine is cold.
    The question(s) is/are - where is the coolant temp measured and why? Is it after the thermostat?
    Note that I no longer have the original thermostat, I've replaced it with a conventional 88 deg C thermostat.
    Nov 2019
    Okay great, similar..
    I've actually just ordered the 88deg thermo too (740d version), incoming from somewhere in the EU. A bit on the nose at 200aud delivered!
    Heres the cooling flow.. A little cross eyed looking at this one tbh. My current understanding is that the lower rad sensor is the outlet, and therefore, as per IID tool, the 90deg value. I took another reading just now after the car has been sitting for a few hours and still, same value. Does the outlet temp sensor control the fan? Cause the fan is generally always on, even when first started in the morning, jet plane, immediately
    A run to the coffee shop and back (about 12km) this morning had the coolant temp at 90 deg C and radiator coolant temp at 76 deg C.
    I plugged my ScanGauge back in (it’s usually plugged into OBD port) and coolant temp was 89.7 deg C so I think we can assume it’s measuring the coolant temp, not radiator.
    The ScanGauge often shows temps well over 90 when the car is working hard or in hot weather.
    Before the thermostat change, seeing 104 was not uncommon.
    Nov 2019
    Interesting, okay I'm going to email GAP to get some feedback on this, maybe its something to do with my IIDTool
    Thanks for your help sir.
    Apr 2015
    Hervey Bay
    Hi lads,
    I checked my temps with my "Launch X431 pro" the other day and my Radiator temp started at 27 deg and rising to 78 deg, while my coolant temp steadily rose to 114 deg. My gearbox came up to 116 deg.
    (As far as I'm aware the standard thermostat is 115 deg with a electrical override switch for high load conditions. I'm not happy with running such high temps as I have a gearbox heater not cooler and I do get problems with high gearbox temps while towing. I do see a drop in coolant temps to 95deg when the gearbox reaches 128 deg, but by then it is too late).
    04 L322 Vogue V8 - Work truck
    07 Freelander 2 TD4 SE - The wifes
    74 Leyland P76 Targa Florio - Aspen Green
    91 Kawasaki GPZ900R
    Previous LRs = 78IIa series - 81, 93, 95 RRC - D2V8
