Results 1 to 6 of 6
Thread: Powered grain mill
    St Helena,Melbourne
    1.13 MB
    Powered grain mill
    I scored a free grain mill while collecting some supplies, not keen on hand milling so started looking at ideas for adding a motor.
    Found a post on AHB where guys were using the motor with pulleys from a bread maker to power their mills, a quick search on gumtree and a cheap bread maker was found not far from home. Adapted the large pulley to the larger mill shaft and mounted the mill and motor to a piece of plywood which was then bolted to the lid of a plastic tub, found a 240V rated switch and a small plastic jaycar box to mount the electrics and all thats left is to paint the plywood.
    Tested out on 500g of spare grain then ran 5kg of dark munich malt for my next brew, gearing was perfect and went thru the 1.2-kg hopper in no time.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Apr 2012
    Whyalla, SA
    Nice work.
    Aug 2018
    Bendigo
    Nice. I'm lazy and just use a battery drill.
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by Fattima View Post
    Thats not lazy, lazy would be buying one already powered for $$$$.
    1974 VW Kombi bus
    Apr 2012
    Whyalla, SA
    Or just buying Beer Powered grain mill
    St Helena,Melbourne
    1.13 MB
    True, but half the fun is making something you like to drink and it keeps me off the streets.
    1974 VW Kombi bus
