Results 1 to 10 of 12
Thread: The rear locker does not disengage
    Teji_walia Guest
    Hi, I have a D5 MY18 3.0 diesel TD6 equipped with an active rear differential lock and having done 78000kms so far . About 15000 kms back the rear locker would not disengage when turning below 40 kmph and this would produce a lot of noise as if the differential teeth were slipping, something like loud thudding noise. Obviously the transmission is taking some abuse. This happens about 50% of the time. I presume it is some software issue where the rear locker doesn’t engage some times. Happens more often when on an incline and the noises are louder. Has anyone else faced this issue? If yes please advise. Thanks in advance.
    Tejinder.
    Oct 2011
    Hunter Valley
    Hi Tejinder,
    I thought the locking diff worked like a clutch so it can partially and fully engage, therefore I doubt that it is the sound of gears meshing but can imagine it causing stress on the drive components. As yours should still be under warranty I would take it in to a dealer as soon as possible. Also record the sound and the 4WD display showing the rear locker not dis-engaging. If anything it can avoid the "we couldn't find an issue" situation at the dealers.
    Ron
    2016 D4 TDV6 Corris Grey
    2018 D5 TD6 SE Silicon Silver - gone
    2011 D4 TDV6 2.7 Indus Silver - gone
    IIDTool BT
    Dec 2011
    Forrestfield WA
    It's highly likely that this is the trnsfer case causing this. It was an issue with L405 Range Rovers and mine had it. You need to change the transfer case oil and recalibrate the transfer case. Of course, it could be the same sort of issue with the rear locker, which is the same sort of clutch system as in the transfer case.
    The symptoms you describe are exactly the same as mine, which was the transfer case. Always when turning at low speeds with slight acceleration or after four wheel driving.
    There were instructions in Topix on what dealers had to do to fix it. That is what my indie followed and it hasn't returned in nearly 80,000km. Mine was at less than 40,000km at the time.
    Bob
    Northern Tasmania
    I had a very loud clunk from the rear once when accelerating out of a tee junction uphill in the wet. It hasn’t done it since, nor have I been in a similar situation since.
    D2a (Sold)
    MY17 D5 SD4 SE (Sold)
    MY19 D5 SD4 SE (with all the options I want)
    Maybe the tyres? My Pirelli Scorpion all terrain plus 275/55R20 with 42k on them now cause the diff to clunk on tight, slow corners.
    Quote Originally Posted by Teji_walia View Post
    Tejinder.
    Sounds like the plates in the diff are shuddering - gripping then slipping (like a worn torque converter) - maybe check oil level and type - maybe add a bit of Dr Tranny.
    Teji_walia Guest
    Thanks Bob for the information. Could you please send me the document tree of topix or the link thereof where this information is given on how to fix this by recalibration etc.
    Thanks a lot.
    NSW SW Slopes
    Tyres could not make the diff clunk - your vehicle has either a TC or rear diff issue.
    DiscoMick Guest
    Have you tried reversing a short distance to see if it disengages?
    Apr 2012
    Greensborough
    rear locker
    Tejinder.
    I have not had any problems with this electric rear diff locker when used off road... probably one thing that hasnt intermittently failed on my D5!
