Results 1 to 10 of 11
Thread: Air suspension slow leak
    Feb 2019
    Blue Mountains
    Hi All. My 2014 1/2 RRS loses height in the front left while parked overnight.
    On start-up the compressor kicks in and I get movement akin to the raising of the Titanic while it gathers up it's skirts.
    I suspect a slow leak in a valve block or bag.
    Has anyone had this issue, and what was the solution?
    Brisbane,some of the time.
    Quote Originally Posted by Nessie View Post
    Been there,mine(D4)was the corner valve,four years ago,and it’s now doing it again.
    Tape with packaging tape from guard to rim,disconnect battery,or leave drivers door open,or pull fuse under bonnet for EAS,and leave vehicle on level ground overnight.
    I can’t remember what fuse it is under the bonnet.
    But doing the above will stop the vehicle relevelling,and will give you an idea where the issue is.
    If only one corner drops,maybe a bag,then you need to leak test with soapy water.If both fronts drop,could be corner valve.Even one corner dropping could be corner valve as well.
    Good luck,it can be a guessing game,but needs sorting or the air compresser will wear itself out prematurely.
    It’s a pity someone doesn’t have a dye that could be put in the system to locate leaks.
    NSW SW Slopes
    Spray the soapy water on the nut at the top of the air-spring, under the bonnet. If no leak there then put vehicle into off-road height, detach the top of the gaitor and slide it down as far as it will go then spray what you can of the air-spring. Next would be to check the front valve block for leaking externally, appearing to be located under the guard liner behind the back of the front right wheel.
    Feb 2019
    Blue Mountains
    Tks Graeme. Just checked this and there is a very small leak at the top of the air spring where the pressure line goes in. It’s minute, but overnight would probably account for the drop. Off to the Indie on Wed for them to look at a solution.
    NSW SW Slopes
    Hopefully its not quite tight enough.
    Feb 2019
    Blue Mountains
    The leak is at the back of the nut. I’ve checked and it is tight. May need re-doing the fitting.
    Feb 2019
    Blue Mountains
    So, all sorted. The fitting at the top had a very minute air leak which allowed the air spring to evacuate overnight. New fitting assembly with feed hose sent up from Melbourne has sorted it.
    Now waiting for a replacement auxiliary battery to sort the start-stop system and all the niggly things will be solved.
    My issue was a tiny hole in the right front bag.
    Corner valve was good this time.
    One would think they would last longer than 8yrs and 85K,but obviously not.
    NSW SW Slopes
    Have your front spring/shock assemblies been replaced due to leaking shocks, a common fault with early vehicles? If so then perhaps a new air fitting wasn't installed at the time.
    Feb 2019
    Blue Mountains
    Bought second hand so precise history unknown.
