Possibly the pollen filter.
YouTube
Peter
 Master
						Master
						I drove through a grasshopper plague recently and now my D4 stinks of BBQ grasshopper puree!
I got to work with the Gernie and cleaned off all the grasshoppers that I could find, but I figure they may have got to the air filter even though the vehicle has a snorkel. The air coming through the air-conditioning still stinks of grasshoppers.
I've had a look under the bonnet but it is not obvious how to get to the air filters.
Does the air-conditioner have its own air filter? If so, where is it located.
Any help would be most welcome.
YouTube
Peter
D4 TDV6 2014, Tow Pro, Traxide, GME, Clearview.
D3 SE 2008 2.7, Traxide, Prodigy P2, Light Force, GME, Sold to my son!
D2 TD5, sold but missed.
 Swaggie
						Swaggie
						The engine air filter is the black box at the RHS front of the engine bay and the cabin pollen filter is behind the passenger glove-box.
If in doubt read the handbook
Might need to check under the cowling below the windscreen. Pull the rubber seal off around the inside rim of the engine bay below the cowling and you should be able to lift and see underneath.
Engine Air intake with a snorkel should not enter the cabin, so it has to be the pollen filter as this is the only fresh air intake into the cabin.
 Swaggie
						Swaggie
						The radiators may be choked with hoppers and enough odour escaping from the engine bay to enter the cabin air intake.
 TopicToaster
						Subscriber
						TopicToaster
						SubscriberIt will be a long process as I have found out. A few years ago I was travelling to Broome and before Halls Creek I ran into several swarms and made the car putrid.
One weekend I was able to get the car into the back of the hangar and started pulling the front apart, and they were in every nook and cranny. I cleaned out as best as possible without dropping the bullbar which I did when I got home to Coffs and had some spare time. I also replaced the cabin filter.
The other day I pulled the LH front inner guard lining off to change the brake wear sensor and there were still some desiccated remains still there.
2012 Fuji White 3.0 D4, Rear view camera, Hi-line sound, E-diff, Xenon lights, ARB winch bar, Lightforce 240 50w HID. Brads sliders.
 Master
						Master
						I found my way to the pollen filter. Clean as a whistle - and no odour.
I'm still trying to figure out how to get to the engine air filter. I wish LR engineers were not nearly as smart as they think they are.
And no, I don't have a service manual!
I've cleaned as much grasshopper from the radiator as I can get at.
 TopicToaster
						Subscriber
						TopicToaster
						SubscriberOpen the bonnet, undo the air filter box top screws, lift off air filter cover?
2007 Audi RS4 (B7)
