You would need to be careful of the front tyres hitting the front of the wheel arch liner when turned close to full lock I reckon. With the extra 20mm offset they will go even closer than 285's on the standard offset. On my RRV, 275 tyres just hit the inside front of the wheel arch behind the intercoolers and that is with standard wheel offset. Have a good look in there with your current tyres and see what is happening on full lock. I didn't think my 275 55 20 tyres were touching anything but I recently noticed that the dust is worn off where they just touch.
It would be best to try to fit a test tyre first if you can, unless others have done it and can confirm that it will fit.
Bob
