Results 1 to 2 of 2
Thread: Nudge bar advice
    SymoLandy Guest
    Nudge bar advice
    Hi Everybody,
    Moving a nudge bar from one vehicle to another.
    1) Does anyone recognise this style / brand of Disco nudge bar? (see photos)
    2) Are there fitting instructions available somewhere?
    3) Anything I should know before I undo the bolts?
    4) Is there a nut on the other end of the bolt or has someone cut a thread into the chassis?
    5) If there is a nut on the other end how the hell do I feed that along the inside cavity of the chassis and get the bolt to line up? (distance is 200 - 250 from the natural breathe hole in the chassis (as seen in the photo)
    Changing from a mate's car to mine and don't want to undo the bolt and not be able to get it back onto mine.
    Symo
    Jan 2014
    Perth Western Australia
    *I dont think it looks overly complicated.
    *Unbolt the front small bash plate.
    *I am guessing the 2 what looks like bolts (circled in blue) go through the chassis, the outer holes are already there, may require drilling out bigger.
    *The inner holes for the bolts that go through the chassis will require drilling.
    *The front bolt (circled in red) I think from memory the hole and thread is already there.
    *You are going to have to unbolt it all and suck it and see.
    Daz
