I’ve had the bike for 14 years now. Purchased it new and slowly did modifications and evolutions over time.
This year I’ve decided I’m sick of Chrome so began the work of modifying it further.
As it was when purchased
Then this:
Was the bike I always wanted back in the day - pretty sure I’d kill myself if I tried one now... 😁😇
Well you better not let me ride that one then either... 😆
Over time it gained:
Power Commander III and then upgraded to PC V
GI Pro Gear indicator with inbuilt ATRE
Speedohealer
Custom made intake pipes and filters - which then became Hypercharger Pro-S intakes
Exhausts have come and gone:
6” custom built pipes and Cannon (off then back on in Black ceramic)
Short dumps - had these custom made and ran for a while.
This set up idles at 94db and is tuned to lower the frequency towards the 20-80hz region. (It barks deep)![]()
Of course, it’s needed bling...
So a remote controlled LED accent light set up (Mk 1) was fitted - single colour
And then it was just ridden for a while.
For a while it sat in the shed whilst the plan was developed.
And then it started:
3” pullback risers
Custom cables and brake lines
Stripped out the Power Commander and other add-ons
*Fitted a Woolich Racing Loom and custom mapped the factory ecu
Problem was that wasn’t enough....
So now it looks like this!
Bits have started to turn around (seem to be home a bit more often recently)
Add the decals and:
