Results 1 to 10 of 32
Thread: Finished the '49 Dodge , but can't road test it.
    Jul 2011
    Yarrawonga, Vic
    After 6 months in Self Isolation I finally finished the Dodge restoration.
    First time its moved under its own power in 30 years, out of the shed for a hose down and back in again.
    Runs like a bloody swiss watch , but not good starting up and idling a new engine without being able take it for a drive and heat cycle it and to re torque down the head.
    Bloody Lockdown means I can't drive to Castlemaine to get a VASS (for the disc brakes), can get a UPV but no valid reason to drive on a UVP matches a valid reason to leave home.
    May 2008
    Bundaberg Qld
    Bloody beautiful
    where did you hide the batteries ?
    Jul 2011
    Yarrawonga, Vic
    Quote Originally Posted by pop058 View Post
    Bloody beautiful
    Thanks, ... Too funny . I did consider converting to EV but when I saw it still had the flathead I knew that was staying in it.
    NSW far north coast
    Bloody beautiful
    Ditto!
    That is very nice - when I was a kid my uncle had the model with the quad front lights and he took us every where in it - went every where a 4wd did at the time.
    They are a great vehicle.
    Back down the hill.
    Gwonn, head to Castlemaine, if you get pulled up tell 'em the computer's just started a burn. You can't stop.
    May 2008
    Bundaberg Qld
    Good call.
    Looks wonderful. I hope to see it some time - A visit here would make a wonderful running in trip!
    What is the reason for the interesting spacing of the spark plugs?
    Quote Originally Posted by vnx205 View Post
    I think you will find the spark plugs are positioned relative to the intake/exhaust valves, probably over the intake valves for cooling with incoming mixture, I'm guessing, and these are in turn grouped in pairs with three branches to the intake manifold, each serving two cylinders.
    I think this sort of layout was pretty common on flathead engines, especially those with more than four cylinders in a bank.
