Results 1 to 10 of 15
Thread: Removing foam insert in boot of 5 seater
    Since I am locked up for a while, I have been coming up with ways to amuse myself... Always a worry!
    Has anyone removed the foam insert under the false floor in a 5 seater. I have been thinking of installing an ARB twin compressor and air tank - I have the one in a box - in there, but the space is too shallow with the foam in place.
    A few photos and some hints would be greatly appreciated.
    Numb Thumbs
    Oct 2011
    Hunter Valley
    It has been done, you could have a look at this post, which has a link to a Disco that has it removed (pictures 5 and 6 in the link). It shows you can put a lot of stuff in the area, but doesn't show it empty.
    Ron
    2016 D4 TDV6 Corris Grey
    2018 D5 TD6 SE Silicon Silver - gone
    2011 D4 TDV6 2.7 Indus Silver - gone
    IIDTool BT
    May 2016
    NT,
    you need to remove the side rails and the metal cross brace at the front of the tray that holds the storage tray at the rear. That means the side trims need to be removed.
    The box is sort of firmly located, but some gentle persuasion will get it out. It's a polyester foam (I think) that looks like styrene, except it is not brittle.
    I'll see if I can find some photos of mine.
    Thanks, Hugh Jars. I am always nervous pulling the side panels off... The battery side is easy - maybe I can get it out with only removing that side?
    What are you doing with the space?
    Numb Thumbs
    May 2016
    You can see I have removed the cross brace and the plastic storage bin near the spare winch.
    In this photo, the side rails are in place, but without the plastic trims attached. Just remove the capscrews, and wiggle them around to free them from the front and rear trims.
    The front lip of the box sits under the front cross brace, but there’s no need to remove it.
    Once you have the 3 metal pieces removed, simply lift the back edge of the box (near the round bits in the middle), and pull the box to the rear to clear the front lip 👍🏻
    Thanks again. What is the roundish thing to the left of the spare wheel winch?
    Numb Thumbs
    May 2016
    That’s my fully sik subwoofer 🤣🤣
    Apr 2012
    Whyalla, SA
    And factor in adding some sound deadener as that lump of foam helps NVH Removing foam insert in boot of 5 seater. You may find a bit more noise with it missing.
    I anticipated a change in NVH, but I hope I can use something a bit thinner...
    Numb Thumbs
