Thread: Analog clock lagging
    Sep 2010
    Dunsborough
    First world problem I know, but heck, I’ve gotta fill my Coronavirus days somehow.
    the analog clock matches the digital readout in front of the steering wheel on startup, but after a while it consistently lags behind the digital jobbie by half an hour more on a long drive.
    Can’t find any similar posts here, has anybody else struck the same issue? Mine’s a 2016 SDV6 SE.
    Apr 2012
    Whyalla, SA
    Your clocks broken Analog clock lagging
    Or you’re driving so fast time is slowing down.
    Nov 2015
    Black Rock
    I think you've misread Einstein...
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Nov 2017
    West of Perth
    Quote Originally Posted by DieselLSE View Post
    It's relative.
    If at first you don't succeed, that's one data point. - xkcd
    2011 Discovery 4 SDV6 HSE
    Apr 2012
    Whyalla, SA
    I know, the theory actually is the opposite. Analog clock lagging
    Quote Originally Posted by GregMilner View Post
    some thoughts..
    You haven't said if the digital clock keeps time with, say, your watch?
    If you don't reset the analogue clock, does it keep consistent time while the vehicle is parked, e.g. overnight (albeit 30min slow)
    If the answer to the above is that the clock is "stable" when all power is off, do you have any added draw on the clock circuit from DIY mods while the engine is running, which may lower the voltage feed to the clock and cause it to lose time?
    Sep 2010
    Dunsborough
    Quote Originally Posted by Hoges View Post
    some thoughts..
    Yeah the digital clock keeps perfect time. The analog clock loses time gradually while driving, but when I switch off and check later without turning the car on again, it's reverted back to match the digital readout. No added draw on the analog circuit as far as I know. A couple of years ago Autospark ran an additional 12v power outlet down to the cargo area for me, and boosted both outlets to carry 20amps, but that's directly off the battery via the ignition switch (they're not constantly live).
    Other than that, the clock issue is a mystery.
