Results 1 to 10 of 12
Thread: Oil Catch Cans
    Feb 2010
    Mount Martha
    Oil Catch Cans
    Hi all,
    Did a search and couldn't find anything.
    I was wondering if anyone has fitted a Provent 200 (or Similar) catch can to their SDV8.
    Looking forward to some responses.
    Cheers, Craig
    Nov 2013
    Wollongong
    Wondering where and how also?
    Mornington Peninsula
    Can someone explain the benefits of a catch can?
    2022 Defender D250 S being set up for touring.
    '83 RRC 2 door 300tdi on club plates
    '82 RRC 2 door almost finished on club plates (will always be nearly finished!)
    2013 Freelander (wife's)
    1994 Defender ute hopefully on club plates one day
    My understanding is that essentially a catch can is already designed in all the V land rover diesels so an after market catch can is not needed.
    Well that was the consensus when these have been discussed in previous threads.
    Feb 2010
    Mount Martha
    Quote Originally Posted by discojools View Post
    Hi Jools,
    Hope you are well.
    I have fitted catch cans to all my diesel vehicles but not the Rangie as yet.
    Here is a good explanation of the benefits of a catch can...... Is a catch can important on a modern turbo diesel?
    Cheers, Craig
    Feb 2010
    Mount Martha
    Quote Originally Posted by 101RRS View Post
    Not sure how they could do this but I will investigate and report back.
    Cheers, Craig
    Apr 2012
    Whyalla, SA
    Quote Originally Posted by Disco4SE View Post
    Cheers, Craig
    It’s only a vapour separator. If you have sufficient pathways you can achieve this in the original design.
    Feb 2010
    Mount Martha
    Problem is..... Most if not all diesel engines do not have this design.
    Cheers, Craig
    There are quite a few threads about catch cans for LR V diesels - do a search and you should find something.
    Oct 2007
    Brisbane West
    To be effective the filter media needs to be fine. Which means eventually it clogs reducing flow and effectiveness. In a Mann Hummel Provent 200, the filter membrane is to be replaced at 40,000 k. The Provent also has a well set up pressure relief valve. Mann and Hummel know diesel filtration. I suppose pressure relief could be built in, but unless the LR has a replaceable fine filter membrane it's hard to see how it could be particularly effective.
    I can't see how any modern TD would not be assisted by a good quality catch can.
