Thread: MSA vs DMax gearboxes and NPR vs DMax engines?
    Bunbury, WA
    I'm converting a 2A FC landy to Isuzu power. Rather than the std 4DB1 route I am aiming to go with the J series family, probably a 4JH1 from a mid 2000s DMax, Rodeo or NPR/NKR truck.
    Gearbox options are MSA/MXR from an Isuzu truck or the manual gearbox from a DMax. There is a huge cost difference between the two options. Like $2,500-3,000 for the MSA box vs <$1000 for a DMax box. Is a DMax box really that inferior to push a 3.5T landy along? I'm intending to run a divorced LT230 transfer so output/mating is not important. All discussions seem to indicate that the DMax is strong and reliable? The only swaying factor is that a remote cable linkage will bolt straight up to a MSA box if it came from a cab-over truck, whereas a custom remote linkage would have to be devised for the DMax box in a FC configuration.
    It seem the same with 4JH1 engines from a Isuzu truck vs from a DMax? Does anyone know how the bellhousings vary between the two source engines?
    May 2006
    Woolgoolga
    Is that reco box pricing?
    Bunbury, WA
    Quote Originally Posted by Vern View Post
    Probably? Just what I have seen online/gumtree etc.
    May 2006
    Woolgoolga
    I would think $1k is cheap for a reco box.
    I paid about $3k for a reco msa, but have bought a couple of good secondhand ones for $800.
    Not sure if the 4j series will bolt up to the msa, my choice would be a 4be1 to msa, or a 4h series to msa/mxa.
    Bunbury, WA
    I believe the 4J series engines are SAE pattern bellhousings like the 4DB series. 4JH1 and MSA5R is definately a combo in abt 2003 Isuzu NPR200 trucks.
    I think there may be a shallow or deep bellhousing difference between the truck and DMax/Rodeo 4JH engines? Thats what im trying to define.
    May 2006
    Woolgoolga
    In that case, i would use the msa box
    Bunbury, WA
    Reaching out to Dougal? He hasn't been on here since Jan 2019. If anyone has an email address for him, could you PM it to me please?
    Chris
    Oct 2007
    Wantabadgery, N.S.W.
    Quote Originally Posted by cjc_td5 View Post
    Chris
    The Dougal
    www.engen.co.nz - Engineering Contact
    Don.
    May 2006
    Woolgoolga
    Chris
    He is on 4btswaps all the time
    Bunbury, WA
    Yep, thanks. I reached him through the 4BT forum. Dougal recons that I don't need a MSA/MYY truck box behind a J series engine. A DMax MUA5G box would be just fine.
