Thread: 6x6 maintenance module electrics explanation
    Sep 2011
    newcastle
    Hello all
    Wonder if anyoune can exlain the capabilities and operation of these pictured electrical components in a 6x6 maintenence module.
    Id like to understand this system and its capabilities before purchasing one of these trucks .
    Quote Originally Posted by theg View Post
    Hello all
    the short version...
    theres a 24v system and a 12v sytem built in to run and test light weight power units like radios for repair.
    theres a 240V system that in some vehicles is run from an inverter and in others requires external power like a generator (the inverter one can also use a generator)
    the long version is in the EMEI.
    Apr 2019
    I spent many a year in a G’mer
    The 12v terminals are only hooked up to one of the Aux. batteries, this used to kill one battery way faster than the other.
    We ended up purchasing a 24-12 converter, this worked way better as it drew from both batteries.
    Good thing Engels run off 12 and 24, although with no low voltage cut out we used to destroy batteries.
    What are you plans, they are a heavy pig empty.
    Have a close look at the hinges on the full wings, I suspect some would have issues creeping in.
    From memory there used to be a battery charger passenger front....we removed ours.
    Sep 2011
    newcastle
    Can anyone identify what items are what in the pictures ?
    Sep 2011
    newcastle
    Im interested in one for an extended bush expedition type trip for start of my retirement . Spend a couple of years in the tropics qld nt and wa . Top end exploring .
    Apr 2019
    I’d personally look for a cargo, if the G’mer is cheap enough ditch the pod.
    Apr 2019
    pic below is pretty much what you see and read. I wouldn’t run off the 12v terminals, I’d buy a 24-12 tranny. I’m trying to remember the trick we used to do for the 240v Power. Have you got a pic over the 240v power, it’s under the flat rear drivers side of pod.
    The black box must be an upgrade, I recall that where the 240v battery charger, again just low voltage outlets. Vice used to store below. The blue ish box might the control the lights/fluros
    the yellow box above the bench holds the fuses and circuit breakers, a volt gauge and a couple of selector switch to choose battery or 240 power.
    The steel drop down bench is Friggen heavy, we used to leave the vice which made it even heavier.
    I wonder if the 240v heater is still at floor level up the front of the pod. They generally got ditched as it took up valuable storage space for either water or goffa’s we’d sell to the grunts.
    Back to the lower in, I think there might have been two 240v circuits, 15amp socket for power in, we would than run a small lead from a power point in the roof driver side rear around to the outside box to power up the lighting circuit.
    Hmm...we rarely used the 240v side as I’d refuse to take the generator. Again valuable storage space taken or it meant towing. Neither were a high priority as having copious amount of water for showering or cartons of goffas was way more important.
    Sep 2011
    newcastle
    Quote Originally Posted by W&KO View Post
    Ive done some online research tonight and found the pod version is 400-450kg heavier than the cargo . Almost 4000kg opposed to 3500 or slightly more .
    I see your point in heavy truck . I like the solid fibreglass though for tree scrapes down the sides rather than cutting canvas sides . Also lockable is good and long life in the weather could save buying new canvas from time to time .
    These are the only reasons I like the fibreglass .
    How poor would the performance be affected as opposed to a cargo version ? Im guessing biggest drawbacks are slow , fuel consumption and getting bogged .
    they're heavy and they soak up load, they bog in and chew rubber as well as suspension bushes.
    one of the ones I craned out of the global explorer back in the day may have had the crane computer getting upset on a nearly 10T radius,
    Apr 2019
    Didn’t think there was only 500kg difference, I suspect your looking at the bush ranger versions IIMV’s.
    Lockable is nice, but it two padlocks for the side and a key for the rear.
    Mine was running at GVM and belting along at a 100 used at least 20L/km. Probably more. I remember one drive Brisbane to Rockhampton and we deliberately didn’t refuel and totally ran out of fuel 60km north of Rocky I.e. both tanks completely dry. We were in convoy so 80-90km/hr. They run pretty good sitting on 80-90....100 is unbearable in stock form.
    A tweak of the fuel pump and a straight through 3” from memory exhaust improves performance for very little outlay. This was a mid under bushmaster but we had to return fuel setting and exhaust back to standard at the end of the trials.
    They were tough on the steel trek tyres but it’s seems not so much an issue with private owners these days.
    It should have a PTO winch fitted, the torque limiter/clutch could do with a tweak as well (I think it’s adjustable) or just engage low range if winch overloads.
