Results 1 to 10 of 14
Thread: Better rear brakes
    Better rear brakes
    Turned up today.. should improve the Perentie braking☺
    Hay Point
    Not so much improve the brakes but no more fiddling around adjusting the shoes anymore. Is that from a civvy defender or a military perentie. The rotor mud shields look like civvy ones that only have a 2 pot caliper and a very small pad area. The military ones are 4 pot and much bigger pad, in fact they are a D1 front caliper.
    Cheers......Brian
    1985 110 V8 County
    KLR Automotive make a disc brake conversion kit.
    Quote Originally Posted by Bearman View Post
    Civvy units...can't see how drums would compare esp off road. ..at all😉
    KLR kit too spendy for the owner.. I wanted D1 fronts but he got the whole shaved unit at a v good price inc up rated axles and flanges. See how they go...D1 fronts can always retrofitted if needed. Looking for a spacer to fit vented rotors to the front now or defer vented ones...etc etc
    99.87 MB
    What do you do there? Replace the County rear axle with a Defender one and change the master cylinder to a Defender one?
    Slunnie
    Swapped out the Perentie diff for the 2 pot caliper/disc converted one which went v well albeit the diff is beeping heavy.
    Bled brakes and test drove. No more spongy pedal and braking much better. Off road brake testing in some muddy slippery tracks also very good.
    We suspect that four pot calipers on the rear may be overkill unless a proportioning valve is fitted.
    Anyhow for a grandish plus freight it has been a good outcome.
    Aug 2018
    Bendigo
    Ah so you bought it! Was going to grab that, was a good deal.
    Quote Originally Posted by Fattima View Post
    Na..we fitted it..but yes a great deal given the upgraded and recond stuff in and on it.
    Hay Point
    Quote Originally Posted by INter674 View Post
    There is already a proportioning valve installed. It's in the 2nd barrel of the master cylinder.
    Cheers......Brian
    1985 110 V8 County
    Kingston, Tassie, OZ.
    Where'd that come from! Looks great!!😊😊
