Hi there. I bought my genuine wolf wheels from Landybitz (here in Oz). They have special on at the moment $179 ea (black). They are stamped with 2200kg. I can send pics if you want. Yes you WILL need the longer studs. I got from UK bearmach or rimmer bro, can’t think at the moment. I also got the nuts from Landybitz. It doesn’t matter if the wheels are rated higher if you axle / suspension is rated lower, you must not exceed your vehicle load rating. I just wanted strong wheels so replaced the alloys with the wolf. Let me know if you need more info etc.
