Results 1 to 3 of 3
Thread: Houston chopper crash discussion
    Sep 2010
    The Hills.
    152.79 MB
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    May 2012
    Wannanup WA
    4.70 MB
    Hmm, there are a couple of things wrong with that. Why he mentioned the height velocity curve I don't know, as a successful landing from there is not likely, tail rotor or not!
    The other thing is if you are fortunate enough to have a tail rotor failure at altitude it is possible to stabilise the aircraft if you are quick enough, but any attempted landing should be a run on to prevent a counter rotation by pulling pitch near the ground.
    RIP to the poor bugger that was well aware of what has happening.
    Reminds me of an incident on the first offshore oil platform in Australia about 1970. A helicopter landing on the platform suffered a tail rotor failure as it was touching down. It killed a TV cameraman who was on the helipad filming the landing.
    The failure of the tail rotor was tracked down to the tail rotor being out of balance due to having a washer left out when being assembled, leaving it out of balance with a resulting fatigue failure.
    During the investigation, the washer was located in the workshop that had overhauled the rotor six months earlier - in between two floorboards under the bench.
