Results 1 to 8 of 8
Thread: Alloy wheels on early Rangie
    May 2006
    Question Alloy wheels on early Rangie
    Anyone know what the difference is between alloy and non alloy type hubs?
    I have a 2 door that came with 3 spoke alloy wheels but no marking on the end of the studs, the wheels appear to fit just fine but I think I will take them off as I don't know what the issue may be, could it be the lenght of the studs?
    David.
    Adelaide - Torrens Park
    What do you mean by "no marking on the end of the studs"?
    I am not aware of any difference between hubs for factory fit alloy or steel wheels.
    May 2006
    The manual states only hubs with a I or V marking on the end of the studs are suitable for alloy wheels, but no mention of a reason for this!
    Avoca Beach
    I haven't checked recently but I believe the alloy studs are longer.
    Regards Philip A
    Yinnar South, Vic
    Early hubs are ever so slightly larger in diameter and make for a really tight fit with standard alloys, a little emery or a buzz with a die grinder soon fixes it but, I know nothing about stud lengths being an issue?
    Nanny state UK...
    As previously mentioned.... If the studs have a marking stamped into them, they are suitable for the factory fit alloy wheels.
    M
    Avoca Beach
    Now I recall, the studs are designed to just come to the end of the nut for a steel wheel, presumably so that the end does not rust etc.
    When I put Disco wheels on my 92 which came with alloys, the thread stuck out about 4MM.
    So if you put alloys on the short stud you do not get full thread engagement in the nuts.
    Regards Philip A
    Mark was right and it is the signs on the end of the wheel stud that idicats if they are ok for Alloys
    But saying that i put a set of alloys on a 71 2 door i owned and they were fine. Just had to check that they were tight now and again. As they did have a habit of coming a bit lose over time
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
