Results 1 to 10 of 15
Thread: Renew shocks inside D3 Air Springs - whosdunnit recently?
    Sunshine Coast - Queensland
    Dear brains trust,
    With a secondhand set of airsprings cluttering up my shed floor, I have decided to try to change the shockies inside the complete airspiring units.
    So to those who have "dunnit", where did you get your shocks? and did you need the seal kit?
    And finally, what should I look out for?
    I'm going to start with the rears and see how that goes.
    Thanks - Matti
    NSW SW Slopes
    I replaced just the shocks on my D4 a few times and have a couple of seal kits somewhere so obviously I didn't always use new seals. The sequence of the o-rings and plastic spacers needs to be maintained to ensure that the o-rings have a proper seat on which to seal.
    Inspect the insides of the air-springs at the folds for cracking before buying new shocks as buying genuine air-springs (only) is prohibitively expensive.
    I fitted genuine D3 shocks, refitted the original D4 shocks for a very short time, fitted complete non-genuine assemblies then genuine LR D4 shocks to the non-genuine air-springs.
    Sep 2014
    Baldivis WA
    Following with interest, the airbags on my D4 are all ok but i think after 200,000km the shock absorbers are getting a bit tired. Would love to change them all out with new shocks.
    NSW SW Slopes
    The insides of the folds of mine were quite cracked at 90K which I did not expect to survive another 60-80K, being the average distance any of my shocks have lasted before they had lost their effectiveness.
    Thanks Graeme - just the info I was looking for.
    The airsprings I have on at the moment are my third set (counting the originals it came with, now at 205K km) and they were installed around October 2018 (approx 160 000km). So they have done 45000km since fitted
    I'm not happy with rate at which these lasted before they became spongy, but there was a caravan thrown into the mix this time.
    You mentioned you have tried D3 and D4 shocks - which one would you suggest is the better and did you source them from a dealer?
    Regards - Matti
    Jan 2020
    McGowanastan
    I have a pdf file on how to do the strip down if you want a copy , it's in 4 parts which includes removal from the car . PM me an email address if you want a copy. It's not perfect but will give you a good idea on how to.
    I was looking at replacing my shocks only with B6 bilstien but with 160k on the original - well except 1 front which got a hole in the bag- a full set of OEM from advanced factors is prolly a better option for me , especially give the cost of the full set of Bilstiens .
    Bulletman
    Quote Originally Posted by Bulletman View Post
    Thanks Bulletman, I will keep that in mind if I decide to go down this rabbit hole. I have a copy of the KONI instructions if that's the one you have.
    I agree that replacing the complete airspring as a unit is an "easier" option, bit the cost is "up there" to say the least.
    I was hoping to get the shocks at a reasonable cost (awaiting Graeme's input as to sourcing shocks) and provide my free labour, but as Graeme suggested, I should pull apart a unit I have and properly assess the airbag before diving in with a"shock only" refurbishment.
    I may get some shed time in the next day or so to have a gander.
    Matti
    Jan 2020
    McGowanastan
    Quote Originally Posted by matti4556 View Post
    Matti
    No worries Matti, I have the Koni pdf as well as the 1 I got off the UK site , which is more laymans than the koni pdf. I never priced up the Original L/R shocks so will be interested in what you find . I know the Bilstiens had to come from either UK or USA so they started to get expensive. I got a spare 2nd hand or used front and rear airstrut that have Bilstein shocks that is why I looked down that path. I also read stories on here of people only getting 40k out of aftermarket shocks ( think it was Terry O ), so was a bit wary of spending up big and only getting low kms before needing another set of shocks.
    Bulletman
    Jul 2012
    Perth- South of the River
    I was just about to post about that.
    I'm no expert but I remember quiet a bit of information a few years ago where a couple of manufacturers tried but couldn't get their shocks to last inside the airbag. It would be worth researching before proceeding....
    Gone 05 D3 ARB Front Kaymar Rear Winch E-Diff LRA Tank Dual Battery
    Current 2015 SDV6 SE. Tow Pro Mitch Hitch Llams C/motives 70ltr w/tank 2 x comp Traxide BMS-2 x Aux 150w Solar Uniden Engel ARB drawer F/Runner rack Light bar
    Apr 2012
    Whyalla, SA
    Airbags over 7+ years and higher kilometres are really not suitable for rebuilding the shock only.
    I’d certainly never trust one.
