By dead do you mean just flat battery dead ? I know you said eastern burbs but where abouts, i have a diagnostic tool and may be able read it for you/her.
Hey Everyone
I am writing on behalf of my mother who has had her Disco 3 recently refuse to start ( after ongoing start issues, most likely regarding the immobiliser)
she's owned this car for 12 years and apart from this issue is in great condition
i've searched the forums but only seem to find some advice regarding D1 and D2s immobiliser problems
Reason i believe its immobiliser, is flashing red light on dash was like it wasn't being unlocked correctly (replaced authentic key fob and changed battery, problem remained)
my questions are , and sorry there are a few
can it be fixed?
How can it be Fixed?
Who can fix it?
How much is it going to cost?
Can you recommend anyone?
Located eastern suburbs melbourne
much appreciated for any replies as i'm not sure who else to ask ( local mechanic couldn't find anything wrong when the issue was intermittent , now its dead)
Richard
Model Specs
Land rover Disco 3 s
Auto , Deseil 2.7
180,000km
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
There could be a switch on the auto to ensure it won't start unless in park. Sometimes these fail and prevent starting at any time. Any auto electrician should be able to fix it.
sorry ill be more specific, Engine won't try to turn over, everything else will work but the immobiliser light keeps flashing like the car is still locked
lights and dash turn on , but wont crank
thought it was a battery , changed that last month
thought it might be the Key , Bought a genuine replacement
located surrey Hills
The closest reliable repairer would be Ritters in Burwood (116 Highbury Rd). Firstly, at least call them for advice. Presumably the car has been serviced by someone who knows what they're doing. Can't they help?
2013 D4 expedition equipped
1966 Army workshop trailer
Have you tried moving the gear lever ? possible its not engaged in Park and the car wont start if its not in park or neutral.
Bulletman
With the ignition key to the on position do the hazard lights come on? They wont be on the dash but will be on outside. If so it could be a canbus issue
Shane
2005 D3 TDV6 loaded to the brim with 4 kids!
http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
 Master
						Supporter
						Master
						Supportersounds like it needs a hard reset. It is worth a try.
remove the battery terminals from the battery ( Both ) and join them together for a while. half hour is good and hour is better.
Then reinstall terminals and pray all will be well.
Let us know if this works please
Ian
Bittern
