20th May 2020, 08:29 AM
Air bag light
Hi all I have a 2002 l322 and l get the air bag warning light on the dash from time to time but only if someone is in the passenger seat and even then the light will come and go lf no passenger no light l have looked under the passenger seat but cant find any loose connections can anyone tell me what to look for
Cheers Denis
20th May 2020, 10:12 AM
Denis
Try pulling apart and cleaning all the connectors, alot of carpet fluff etc over 18 years can eventually get in the plugs ! Also try moving the seat back and forth to see if that triggers the light. Wiring might be getting rubbed/caught near the seat rails.
Laurie
20th May 2020, 10:29 AM
Manny thanks Laurie will try this afternoon and will post the results
Cheers Denis
20th May 2020, 08:19 PM
#4
I had the light come on in my MY08. The IID Tool identified the fault was the seatbelt pretensioner. It was caused when the seat was moved, and was a wire going into the pretensioner. I zip tied it secure so it didn’t move which fixed the fault.
L322 tdv8 poverty pack - wow
Perentie 110 wagon ARN 49-107 (probably selling
) turbo, p/steer, RFSV front axle/trutrack, HF, gullwing windows, double jerrys etc.
Track Trailer ARN 200-117
REMLR # 137
21st May 2020, 11:02 AM
#5
Air bag light
Thanks to all for the info but I have cleaned all connections and wiggled the wires
21st May 2020, 11:13 AM
#6
Sorry put the tablet down and hit send oops
Back to the little red man he does not show up with driver only but soon as my wife sits in the passenger seat hello red man maybe I will ask the wife to sit in the back
I think I will keep on looking for the fault
Any more help would be appreciated
Regards denis
21st May 2020, 11:38 AM
#7
I’m thinking it might be caused by movement of the seatbelt stalk. Maybe move and resecure the wire into the seatbelt stork pretensioner.
REMLR # 137
21st May 2020, 03:44 PM
#8
I have checked the seat belt con seems all ok
With the car running if l sit in the passenger side it takes about 6sec for red man to light up
22nd May 2020, 08:54 AM
#9
REMLR # 137
22nd May 2020, 09:41 AM
#10
Usually on later cars there is a sensor in the seatbelt which advises when the seatbelt is connected.
If someone sits in the seat and the seatbelt is not connected the warning light shows.
I know if I put something on the seat of my Jazz that the light illuminates.
This needs a pressure sensor in the seat base and a sensor in the belt.
if the belt sensor was crook then what you describe would happen.
I don't know whether this applies to your older car.
It could be that the pretensioner has gone out of resistance spec and needs replacing . If the pretensioner is the same as a D2 it has a set resistance which is read by the BCU.
Regards PhilipA
