Page 1 of 11 123 ... LastLast
Results 1 to 10 of 101
Thread: #137B 2A FC rebuild
    Bunbury, WA
    #137B 2A FC rebuild
    A month ago I saw a Forward Control landy come up for sale only 10 minutes drive away. I've been after one of these for ages and couldn't let this opportunity pass....
    So off for a look see, and a couple of days later picked up this.
    This won't be a "rivet counter's" restoration. This will be a rebuild with quite a few modifications in the name of useability. I want a reliable long distance touring vehicle with a heap of space up back for a canopy body. Some mods will be:
    - Toyota 60 series axles for a 150mm+ track increase.
    - Isuzu diesel with 5 speed box.
    - Modest cab extension.
    - Power steering
    Bring on the fun!
    Bunbury, WA
    Within a week it looked like this.
    There are a few rust sections in the chassis. All patchable.
    Bunbury, WA
    And now it looks like this. Chassis blasted and primed. Now I can see what I'm dealing with.
    This weekend I'm having a crack at removing the spring chassis bushes. Fun fun fun.
    Great find but aren't they so ugly - not like a 101 .
    I hope it all goes well .
    Bunbury, WA
    Quote Originally Posted by 101RRS View Post
    Hahaha. I'll stand out that's for sure! I think a modest bullbar will break up the front "ugliness" a fair bit.
    Bunbury, WA
    Home made bush extractor in use. 2 down, 2 to go. The last front one is going to be fun. The bolt is seized solid in the bush. Hopefully I can drill through the rubber with a hole saw with no centering bit.
    A circle of 5-6mm holes through the rubber should work.
    Aug 2010
    Sunbury, VIC
    Looking forward to this build. 👍
    Sounds like the upgrades will give you a great vehicle. 😊
    Bunbury, WA
    Be off with you, you little ****s.
    Glad that job's (half) done.
    Nice! It looks like a fairly substantial chassis. I'm not sure that it will flex that much when off-roading!
    Will you use it as a trayback ute or make it into a camper?
