Hi all I have a caravan with led lights on it , does it matter if the green trailer light on dash does not come on when indicating or do I need to get the fix done. Thanks
Do you have a D3 or D4?
With a D3 you need a pulse buster to stop the caravan LEDs pulsing. The pulse buster will also then let the D3 know you are towing. This will illuminate the trailer icon when indicating, disable rear parking sensors & rear fog lights, disable automatic height adjustment when changing Terrain Response settings (Manual height selection still possible), and change the shift points on the gearbox.
If you have a D4 you do not get the trailer LEDs pulsing so not totally necessary to do anything. But if you still want the D4 to know you are towing you’ll need resistors fitting to the trailer indicator wiring circuit.
My solution on my D4 LED trailers
2014, MY14 Discovery TDV6, Fuji White (2018-Now)
2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
I have the resisters fitted to the vehicles rear indicators,with a switch,so i can use any trailer with LED's.
Where does one get a pulse booster for a D3 please?
Rob
