Originally Posted by
Alex4398
Not many people out there running the 1.301 ratio from what i've seen. A lot more running the 1.222 from the discos.
I recently fitted a disco one to see how it goes(ive got a td5 though) and its so much better on the freeway, definitely have to change your driving style now and let the turbo spool and the engine rev rather than the quick shifts with the 1.4 case. Only issue is you notice it a little bit on big hills taking off in first gear it can be a bit high. Im running standard 235 tyre size and id be nervous about going to 33s or bigger now, if i do move to 33s ill probably look at getting my case rebuilt with a 1.3 ratio but its a lot of coin.
