Thread: DVD Help needed
    May 2002
    Heathcote (in "The Shire")
    DVD Help needed
    I've got a couple of DVDs that nothing seems to play (they were sent out from the UK for my father).
    I can see the files on the disk
    DVD has a volume label of MEI_UDF
    and a folder named DVD_RTAV which contains 3 files
    VR_MANGR.BUP
    VR_MANGR.IFO
    VR_MOVIE.VRO
    I know they are not the normal DVD set and as I said I'm trying to work out what they were created with (or even if its a complete set) then I might be able to re-burn them so he can watch same.
    Any help appreciated.
    Martyn
    Williams West Aust
    Hi Bushie
    Its possibly the "region code" thats causing probs.
    Cant know how you get around it,but we have been given pirate DVDs to watch that have worked on other machines but dont on ours.Apparently there are ways of unlocking the region code on a DVD player but I think it involves visiting a "shark" at weekend markets.Same thing with Playstation etc game consoles.
    Goodluck
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Lyndhurst, Vic
    Quote Originally Posted by Bushie
    VR_MANGR.BUP
    VR_MANGR.IFO
    VR_MOVIE.VRO
    Martyn
    If this was a compiled DVD disc, meaning a disc that's capable of being played through a home DVD player it would only contain TWO folders;
    1. VIDEO_TS
    2. AUDIO_TS
    This obviously does NOT, so it would suggest that's a Disc containing some Video footage shot on a DVD camera....Yes ????
    If so, it will be in the cameras' native format.....Home DVD will have no idea how to transcode them..
    try this for an experiment, try playing this DVD in your Computer using Apple's QUICKTIME PLAYER(downloadable for free), or REAL player(also downloadable), Windows media player will NOT be able to play these....
    Let me know how you go with this, and we will narrow things down further....cheers...
    Some general reading on DVD files are here, see how you go;
    http://www.pcstats.com/articleview.cfm?articleID=1635
    May 2002
    OK narrowed it down a bit further,
    The .VRO file will play in windows media player.
    It is a movie that has been recorded on a DVD recorder. (maybe not finalised)
    Now I only have to work out how to convert it to a compiled ? DVD that will play on a home player.
    DVD decrypter didn't seem any help and DVD shrink won't recognise it because its not VIDEO_TS etc.
    Martyn
    Somewhere else, QLD
    Video files
    Howdy: The key is the filename MEI_UDF.
    Those videos were written by somthing in UDF format. Most probably a DVD RAM type recorder. (Panasonic?)
    Go to : http://en.wikipedia.org/wiki/Universal_Disk_Format
    for info.
    And : For the 2nd bit the ..VRO extension
    go to
    http://club.cdfreaks.com/showthread.php't=90449
    where they discuss ways to convert the main file - the vro you have- to somthing managable.
    If windows will play the vro file, maybe your video editing tool ( Nero or Ulead?) will recognise the video file and you can import it to make your own DVD. Then it will be in the right format for generic DVD players.
    Now you know where it came from, you should be able to convert it back to regular DVD
    Langy
    hi if u are looking for a way to convert these files to work on a dvd play check out doom9.org and videohelp.com both have programs and tutorials to help u work it out hope this helps you
    Duane
    May 2002
    Thanks for the help guys
    I managed to track down a trial copy of TMPGEnc DVD Author 2.0 which will read the DVD RAM and convert to "normal" DVD files.
    http://tmpgenc.pegasys-inc.com/en/product/tda20.html
    Have to tell the old man to make sure he's sent DVDs he can play in the future.
    Martyn
