Hi James
I have a 2013 D4 SE model. You will find either stereos superb. It's like the difference between 10 and 11 :-) I don't know about Windsor leather but like all leather you do need to look after it.
Your very lucky to find one with 100,000 km. That's low km for that age. The most important is a pre-purchase inspection and drive it. Even if your not a mechanic you can look, list and feel for things that might be wrong. Does it drive smoothly? Does it brake in a straight line? Change the gears into all the lower ranges and listen and feel for any harshness. Test low range also. Test the raise and lower of the suspension. Get someone to look for smoke out the exhaust. Look for any uneven wear on the tires. Even if you find problems they may minor and quite fixable and well worth it if the price of the vehicle is right. Look at the roof to spot hail damage. Look underneath to spot damage due to off roading :-) Open the bonnet and have a good look.
Others here will chime in with more tech advice. Make sure you get the two keys that it would have come with. Replacement keys are pricy.
My wife and I absolutely find our D4 to be fantastic to drive.
Mike
