Results 1 to 10 of 23
Thread: Sagging driver's seat?
    May 2017
    N/A
    I've always found my D4's seats (HSE, electric) pretty comfortable on long days, but the left side of the driver's seat appears to have recently developed a sag, which gets uncomfortable pretty quickly.
    I've done a search but can't find any specific references to it on Aulro - has anyone else had this issue come up or have any suggestions as to causes or fixes?
    Arapiles
    2014 D4 HSE
    Apr 2012
    Whyalla, SA
    Either a support underneath has gone or the foam has given up.
    You can buy the foam for about $65 and rebuild yourself.
    Nov 2015
    Black Rock
    What Tombie said.
    The seats are relatively easy to remove and disassemble. Replacing the foam on heated seats can be a bit tricky, but you may only need to bolster the sagging bit. But first, raise the seats and look underneath. A spring base support may have come adrift and it may simply be a case of clipping it back into place.
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Mar 2016
    Blackburn, Victoria
    The other option (which I took a year or more back as a preventative measure) is to swap the driver and front passenger seat bases over. I have heated (alpine) but they are a direct swap.
    Only issue is you no longer get the warning of feeling passenger not wearing seat belt when the vehicle starts moving. However I find that a positive feature when moving slowly around camp, wood runs etc where seat belt not strictly required.
    For me the driver's side outer cushion was starting to soften but the passenger seat had little use (this was 20k ago at around 185k). Swapping them had the advantage also of reversing wear patterns.
    May 2017
    N/A
    Thanks all, I'm going to have a look under it tonight to see if there's anything obvious.
    Arapiles
    2014 D4 HSE
    Oct 2012
    Quote Originally Posted by BushDisco View Post
    This is a great idea! How long does it take do you think to remove and swap bases? Mine is poverty pack with no electrics.
    My drivers side is splitting at the entry side which would be hidden if on passenger side.
    So the weight sensor on the passenger side cannot be swapped?
    Mar 2016
    Blackburn, Victoria
    Doesn't take long to swap bases, 30 minutes tops to remove, swap and refit. That included vacuuming the +×÷÷= from underneath!!
    Didn't attempt to swap sensor over as the leather is glued to foam and it didn't bother me. Electric heater sockets were a direct swap over.
    Dec 2011
    Adelaide
    142.79 MB
    Do you need to remove the whole seat, or can the base be removed on its own?
    2012 L320 Range Rover Sport Fuji White
    REMLR 012
    No 5 Trailer ARN 177-295
    2006 Disco 3, 4L V6 Petrol SE Deceased Feb 26 2023
    SOLD Engineers Trailer - no id
    SOLD RAAF 231194 Perentie 110 GS - SIR ANGUS
    SOLD 4MP COY Series 3 FFR 30-209
    Mar 2016
    Blackburn, Victoria
    The base can be removed easily by itself. 4 bolts or screws underneath each (can't remember which as it's been a couple of years).
    Oct 2012
    But I’m guessing you need to remove the whole assembly then remove base, swap and replace
