The inlet manifolds, which cover the whole top of a head, on early engines are prone to cracking, with the right one (driver's side) the most common one to split first. Some people, including some workshop operators, advocate only replacing the leaking one as there's not much time saved by doing both together. My son's 2010 split the driver's side a couple of years ago but the passenger side is still original. The replacement manifold has obvious strength improvements.
There are lots of posts on the forum about the split manifolds of earlier engines.
