Results 1 to 2 of 2
Thread: What to do about Diesel Particular Filter problems
    Oct 2007
    Diesel particulate filters (DPFs) are an effective means of minimising emissions of dangerous fine particles in exhaust emissions.
    But if you think about it, DPFs are a band-aid remedy, because diesels can’t burn the fuel clean enough under all operating conditions. DPFs can bring with them a whole new range of expensive, annoying and inconvenient problems. However, there is already a simple, low cost solution available, which addresses the root cause of these problems.
    What is required is to clean up the fuel burn, rather than relying wholly on the DPF to "after treat" the problem! This means that less soot is produced in the first place. FTC Decarbonizer, already proven in underground mining applications, acts as a true combustion catalyst to reduce the rate of soot production, and burn off existing soot at much cooler temperatures than the DPF requires to work. Once introduced into the diesel, less soot (and ash) can accumulate in the DPF, as regeneration occurs naturally during normal engine operations.
    DPFs particularly cause issues for non-highway type applications, and the following series of problems can progressively develop…
    1. The number of "forced regenerations" increase, necessitating the truck to be parked for up to 40 minutes, to burn off the soot under high temperature, high fuel usage conditions.
    2. Where such regeneration cycles have become ineffective, DPF cleaning or replacement of damaged units is required, and both are expensive. Think up to $5000 for a new DPF!
    3. Some of the excess fuel required for regenerations can get past the rings into the oil. This causes excessive fuel dilution of the oil, which in turn, increases the frequency of oil changes. It reduces the oil’s viscosity, which also increases engine wear.
    4. Crankcase oil should be free of fuel, and levels above as little as 5% are unacceptable. In practice, fuel dilution of up to 50% can occur, and this will destroy engines in a short time.
    To counter this series of problems, FTC treated diesel results in a reduction in both the total number of soot particles, and the total soot mass produced.
    Secondly, FTC forces all carbon in combustion and exhaust spaces, including any soot trapped in the DPF, to combust at temperatures as low as 350C. Normally, soot will only combust in the 500C, and above range. The FTC catalysed fuel burn permits the cooler soot burn. As soot is the initial binder for ash forming in DPF’s, the amount of ash accumulating is also reduced.
    FTC Decarbonizer is a very low cost solution, which addresses the root cause of these DPF problems. In doing so, it minimizes the need for DPF regeneration cycles, because less soot is formed, and any accumulated soot is readily combusted under even light duty cycles.
    Hope you find this information useful.
    Brid
    W: costeffective.com.au
    E: sales@costeffective.com.au
    P: 07 3376 6188
    Replies and comments have been moved to What to do about Diesel Particular Filter problems
