Page 1 of 5 123 ... LastLast
Results 1 to 10 of 47
Thread: Small equipment tyres always flat- solutions?
    Jun 2008
    Drouin East, Vic
    I have numerous pieces of equipment with small pneumatic tyres, such as log splitter, towable weed sprayer, wheelbarrows etc. It is almost a ritual to have to inflate a tyre when using a piece of equipment that has not been used in a while. I know I'm not the only one who has this frustration, I'm wondering what solutions others have used to overcome it.
    Apr 2012
    Whyalla, SA
    Nitrogen
    Mar 2016
    Adelaide
    I’ve replaced my wheelbarrow wheel with a solid rubber one. Same for the hand trolley.
    "Land Rover - making mechanics out of everyday motorists for nearly 70 years"
    Jul 2011
    Yarrawonga, Vic
    Nitrogen
    LOL
    Jul 2011
    Yarrawonga, Vic
    Quote Originally Posted by John_D4 View Post
    Ditto, Solid tyres , haven't had a flat on the wheelbarrow in 3 years, They are the only solution.
    solid wheelbarrow wheel | eBay
    Torres Straits
    How do the solid barrow tiles go when you say have a load of ‘crete or firewood and have to bump the barrow up a small step - I split the height of steps with lumps of wood or a ramp but often find I’m using the bounce in the tyre to get up??
    My frustration is the water drain / Dump valve On my compressor takes about three weeks to close - just before the tank fills so to put a squirt in the barrow Or Zero tyre the air compressor uses about 63kWh of Juice for one quick blast of air!! !!!
    S
    Nov 2008
    Mostly over there
    22.04 MB
    I used some polyurethane spray foam (Bunnings filler shelf) on a gap around window (on the prevailing wind side) in a small shed I'd built a while back and then looked at the tyre on my old wheelbarrow. Flat. Shook the can... empty.
    Might get around to trying it one day. Like you, I get annoyed at constantly inflating tyres before using the equipment. When I saw the foam expand and fill the gap around the window and then set I figured it might be worth a go. I think if I did do it, I would pull the tube out and just fill the tyre cavity up. Trim any excess if it emerges and hope for 'roundness'.
    Feb 2013
    Wamuran, Qld
    I dosed all these small tubes/tyres with Slime Tyre Sealant. Seems to have largely solved the issue for me.
    Ron
    2013 D4 SDV6 SE
    Narre Warren South
    There are companies that will foam fill them.
    We used to get Industrial Sweeper tyres foam filled to make them puncture proof.
    Try a forklift tyre place like Tyrefill Pty Ltd Melbourne
    Not sure of price so it may not be economical..........
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Jun 2008
    Drouin East, Vic
    Quote Originally Posted by RHS58 View Post
    That looks like the most economical solution to try, the solid tyres are a very tempting option but would really add up in price by the time I replaced the wheels on all of my equipment. Not talking thousands but certainly several hundreds of dollars. As for nitrogen, I'm using 78% in all of my tyres at present so not sure how a purer sample would stop leaks?
    Is the green slime readily available?
