I know u are in W.A but you could give ritter automotive a call in melb they have a great LPG system for the DII
Mick
Calling Disco V8 owners who have their Discos on gas. I am intending to buy a Series 2 V8 and need to know what gas system - particularly tank configuration - anyone is using. I am interested in the multiple tank ( scuba type ) set-up that is available, one that minimises the area the tank influences in the rear. Any info will be appreciated.
Mick
Hi Maggsie
You will need to do a bit of research.As far as I know the engine management system on the Disco2 isnt happy with a dual fuel setup.I contacted a few converters around Perth 12 or 18 months ago when I was looking at a Disco2V8, and all said no can do.The newer systems may be able to match the Discos electronics,MickRangies contact would be worth talking too.
You try and find a Disco2 V8 on gas,they dont exsist,whereas there heaps of the Disco1 V8s on gas.
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
Guy's,
With the D11 dual fuel dillemas, would it be a solution to install an aftermarket ECU such as a wolf or haltech that has dual setting or multiple setting capabilities. Means the MAF can be thrown away as well.
2011 Discovery 4 TDV6
2009 DRZ400E Suzuki
2003 WK Holden Statesman
Departed
98 Ducati 900SS Gone & Missed
Facta Non Verba
Thanks for the info, I am intending to buy the vehicle in Victoria as there are more available and marginally cheaper plus I have a wholesaler who will be looking after me.
Update on the gas. Looks like the Disco 2 V8 management system and gas are not compatable, apparently the 'OBD 2 System has innumerable sensors that create havoc when the dual fuel is installed. Therefore the V8 is a non event for me. I'll have to look at a diesel disco or patrol.![]()
Hi Maggsie
There is a nice looking TD5 Disco2 on ebay,$19990 buy it now,located is Tassie 180000ks.
There are several others including a Disco2 V8 with FACTORY LPG(No such a beast![]()
Andrew
