Thread: Which non Landrover Brake pads for L322 4.4L TDV8
    Dec 2008
    I am in the process of replacing pads for my RR.
    Got some Bendix pads today but the recommended ones won't fit. Rear was DB1397EURO+ and front was DB2073HD . They are way to small and the wrong shape. Checked a few Bendix dealers(including REPCO) and there appears to be problem with their catalog. It might be that they are for TD6 or the 3.6L TDV8 but they are not suitable for the 4.4L TDV8. Has anyone with the 4.4L used non genuine pads., if so what are the correct part numbers? The RDC rotors fit fine by the way.
    NSW SW Slopes
    I've had TRW GDB1834 fitted for a couple of years and will fit the same next time.
    Rears are TRW GDB1824.
    NSW SW Slopes
    They're currently $13.50 at Repco if you can find a nearby Repco store that has them.
    Dec 2008
    Repco Fornt Brakes at $13.50
    Pity no stock, probably a typoe should be about $113.50. Deler has then for about $350
    The specs of the TRW parts match my existing pads - will track them down tomorrow.
    The Landrover Rears are originally Ferodo and the Fronts TRW
    5CP
    May 2013
    Bittern Vic
    I use Repco pads if they are available. Repco pads are good.
    There should be pictures of the pads online to check which shape you have.
    Ian
    Bittern
    NSW SW Slopes
    Quote Originally Posted by vk5cp View Post
    Yes, probably a typo but that wouldn't stop me from trying to buy them at the advertised price! Its the same clearance price that Repco had a year or 2 ago, but I couldn't find any stock at any nearby store at that time either.
    Mar 2007
    I used Ferodo last time ! around $112 from Karcraft. Tony at Karcraft said they were the most popular purchase, they come with retaining clips and bolts.
    Laurie
    2010 TdV8 Autobiography, D2 Td5, RRC 4 Door VM/300Tdi, RRC 2 Door V8
    Dec 2008
    It wasn't a typo
    Rang the local repco who told me he had no stcok but to check with a store in VIC and WA. I now have 2 sets of front pads in the post at $18.95 each!!! Better than $350.
    Got the rears pads and rotors done today. Thanks for your help.
    NSW SW Slopes
    I too now have 2 sets ordered but from 2 different NSW stores, costing $23.40 each including delivery. Each store only had 1 set.
    Dec 2008
    Repco discount
    If you become an Ignition member (free) they halve the freight to $4.99
