IS it aluminium?
If you can use copper,its around, but in 1/4",which is around 6.3mm from memory.
Hi all, where can a find 20cm of the tube as per the pic. It runs from the no return valve into the controller. I’ve called everyone from enzed to pilot air and no one sells them. Thanks heaps
IS it aluminium?
Hi,
Yes it looks like something between alloy and lead as it's very brittle ans soft. If I can just find a place where I could by 200mm....
Did you ask Enzed or Pirtek about nylon? I bought some from one of the them for P38A EAS air lines.
If you can't find any, I can send you some.
Hi, i bought some nylon 6mm, unfortunately the fitting on the non return valve is not a compression type. Instead the alloy was flanged out and fits without a compression fitting. I’ll go down and add a pick in a bit.
We use something similar on magnahelic gauges,its aluminium.
But i need to measure it to see if its 6mm or 1/4 inch.They do have a similar fitting for the end,but don't know if its the same as yours.
Is yours exactly 6mm?
Cant do this with the nylon...
Sure can - heat gun. Nylon is a thermoplastic and can be reshaped pretty much endlessly - but get it too hot and it becomes a blob pretty easily. Heat it gently and push it onto something that has that shape - when it cools, it will stay that way. It won’t lose strength doing this and will take the pressure no problems.
You might find that bit of pipe will get too hot for the nylon and end up blowing out
1985 110 Dual Cab 4.6 R380 ARB Lockers (currently NIS due to roof kissing road)
1985 110 Station Wagon 3.5 LT85 (unmolested blank canvas)
