Results 1 to 3 of 3
Thread: 3.6 TDV8 DPF sensor 3 bank 1 ?
    Jul 2014
    west of Transylvania
    Hi guys. i need some help to help a friend with a 2008 3.6 TDV8, after i digged in the WSM and diagrams and everything i cant figure out which sensor it's about,
    the code is P242D-00 Exhaust Gas Temperature Sensor Circuit High Bank 1 Sensor 3 - Diesel particulate filter temperature sensor circuit....
    i found the layout so can anyone tell me please which sensor is nr 3 according to the numbers in the pic ? or at least which is ''bank 1" to try to eliminate some
    1 Temperature sensor
    2 Temperature sensor
    3 Differential pressure sensor
    4 Differential pressure sensor
    5 Temperature sensor (2 off)
    6 High pressure sensor pipe (2 off)
    7 Diesel Particulate Filter (DPF) (2 off)
    8 Temperature sensor (2 off)
    9 Low pressure sensor pipe (2 off)
    Mar 2007
    Australian Spec L322's don't have a DPF ! Is the car a imported vehicle ?
    Laurie
    2010 TdV8 Autobiography, D2 Td5, RRC 4 Door VM/300Tdi, RRC 2 Door V8
    Jul 2014
    Sorry, i didnt know there is no DPF in Australia ... the vehicle is in Europe.
