Results 1 to 4 of 4
Thread: D4 Rear Windows not working?
    Woody523 Guest
    Has anyone experienced the rear windows of a D4 not working? I've tried a few diagnostic tips but no luck? Is it a known fault? Any advice appreciated. Woody
    nomys1971 Guest
    had this problem it was carbon buildup on contacts inside switch on center console. I just pulled it apart cleaned contacts and put it back together.I found out by swaping with a known working switch.
    Brisbane,some of the time.
    Lock button pushed which stops rears opening?
    You have probably checked it,but just starting with the simple obvious helps sometimes.
    Nov 2023
    Rye VIC
    I know it’s a bit late, but might be helpful for someone else. I had this issue with the rear windows, and others, after a flat battery and a jump start. After the battery was charged I disconnected the battery for a reset and that cleared out the gremlins.
