Results 1 to 10 of 12
Thread: Coolant leak at hose ends - solutions
    May 2006
    Yack
    2.78 MB
    I have had an irritating problem with (very) minor leakage at cooling system hose ends on the D1.
    Mainly the WP outlet above the alternator ( drips onto body ) and the bottom hose.
    I have changed hoses and clamps, cleaned mating surfaces, tightened and retightened clamps but still persistent minor leaks.
    So I am thinking of changing clamp type to a constant torque style.
    Like this Hose Clamp - Constant Torque - 57-79 mm - Stainless Steel - CT 300 LSS - Breeze - 10/Pack | Hose Clips – Stainless Steel – Norma | Clamps & Clips – Hose | Hose & Hose Fittings | Blackwoods
    or this https://www.ebay.com.au/p/1071652197...gaAmQCEALw_wcB
    Opinions?
    My third 98 D1 300tdi Auto -now registered
    81 Rover SD1 manual - long term project
    Oct 2012
    FNQ
    Quote Originally Posted by edddo View Post
    Opinions?
    Mikalor T bolt style stainless only way to go
    AM
    May 2006
    Yack
    2.78 MB
    Thks AM
    I have some..they are too wide for the WP clamp.
    And I dont want to drain the coolant just now, to fit one on the bottom hose.
    But will try one there eventually.
    So I might try the constant torque ones for now.
    Dec 2008
    Victoria
    Is it a case of the hose going hard with heat and age and not being pliable enough to make a leak proof seal?
    Avoca Beach
    If they are new hoses and red coolant , just wait a few hundred kilometers and they will seal up. They drool for a while.
    I now use the factory type sprung clamps as they keep a constant pressure unlike the screw type which ease off as the rubber hose compresses.
    Regards PhilipA
    NSW far north coast
    Regards PhilipA
    Ditto.
    Constant pressure worm drive clamps are available but not easy to come by.
    Brisbane,some of the time.
    What rick said.
    But if you still have issues,which you shouldn’t,if there is room put one clamp beside another on same hose if you know what I mean.
    Done this on corroded coolant parts,and it’s worked,mainly on old Holdens years ago,water pumps,thermostat housings,etc.
    Sep 2014
    Hunter Valley NSW Australia
    Another solution along with constant pressure clamps is when fitting the hoses coat the spigot/neck with Permatex No 3 (the brown tacky stuff that gets on everything ;-))) it makes a good seal especially on alloy fittings and stops coolant getting between hose and spigot and causing corrosion. It also make hose fitting and removal much easier as the rubber doesn't grip/bond to the fitting allowing hoses to slide on and off when clamps are loosened.
    May 2006
    Yack
    2.78 MB
    Thanks for the info and ideas.
    Fyi - new hoses and Ethylene Glycol green coolant ( Nulon I think).
    Can get the constant torque clamps on ebay and elsewhere.
    The Permatex 3 doesnt add to slipperiness does it? ie risk of sliding off higher under pressure?
    Sep 2014
    No it dries and sticks, helps seal the hose against the fitting really well but allows the hose to be removed easily. By sealing the hose to fitting interface it also stops the alloy fittings from corroding as they are wont to do.
