Thread: Advice on Cylinder 1 Please
    Jan 2017
    Gentlemen,
    I honed the bores on my 1953 Series 1 that is running a later Spread-bore 2litre motor.
    When I took off the head, cylinder 1 yield up the top compression ring in multiple pieces. Cylinder 1 also has a worn gudgeon Pin, plus two shallow score marks in the piston skirt.
    Todays hone showed up some score marks in bore #1 but in none of the others.
    The advice I need is a sense of now critical these score marks are in #1. I've provided two pictures from slightly different angles. I'm hoping you experts can tell what I should do with it.
    I had desperately hoped that I could replace piston #1, put new rings in all round, and reseat the values, which are all OK in their guides but need reseating, not replacing. If that plan was possible, then I could do the car myself at home without breaking the bank, which is under severe stress while I try to bring up the family on $1,500 a fortnight, thanks to the Pandemic.
    So, can I still do this or are the score marks in #1 so bad that the engine has to come out, be sent off for reboring, and about $5,000 worth of parts required to put things right. If that is the case, then the car will have to come off the road and be stored for a few years while I get my self back on my feet.
    So can I proceed with plan A and fix it at home, or is it out under tarp for a few year?
    What should I do?
    regards
    Jeff
    Jan 2017
    Advice Please
    Sorry, I forget to add that I can see these marks but cannot feel them with my finger nail.
    thanks
    Jeff
    Hi Jeff - Sorry not following - what marks - what are you enquiring about.
    Edit - just spotted your other post - I guess you created a new thread instead of a new post in your other thread - maybe the mods can move this for you.
    As top your question - sorry I do not know if it is an issue but it is wise to ask
    Feb 2011
    Rileys Hill
    Hi, It looks like the marks are not bad enough to have to re-bore.
    A good hone should do the job.
    When you hone move the hone up & down to get a good cross-hatch.
    Also it looks like there is a lip at the top of the cylinder. Concentrate on getting rid of that otherwise you will brake the compression ring.
    Paul.
    Apr 2007
    NW Tassie
    its not a race car, worst case it may use a little oil and maybe a bit of compression but you wont notice in day to day running
    blaze
    Threads merged
    not optimal but it does look like honing has already started to blend the edges.
    for occasional use and low power use it wont be too big of a problem but if its going to be a daily.......
    I'd be doing a hone up till the marks were barely perceptable checking out the overbore dimensions and seeing if it was still in tolerance for the piston/ring limits. IF it is build it and send it. if not, its time to bore it, oversize it or line it then build it.
    Aug 2015
    Moe
    For what it's worth, back in the early '70's my SIIa developed a "noise" which transpired to be a LOT of broken rings with #1 being the worst with all rings broken and the piston cracked. There was a rounded groove down the thrust side of the bore about 0.5 - 0.75 mm deep and about 5mm wide and about the radius of a one cent coin. All I did was a quick hone, a set of new rings in all cylinders and a new piston in #1. It was as right as rain for the next 30k miles until I sold it and got a diesel SIII. Between them the other three cylinders only had a couple of compression rings intact and all the oil control rings were broken.
    Given my experience I wouldn't be too concerned at all about the markings that you have.
    Mark F...
    Vk3KW
    2002 D2 Td5 auto - current AKA The Citrus Money Pit
    2000 Disco 2 Td5 Manual - dead and gone
    197? Range Rover - gone
    1973 SWB SIII Diesel, 1968 SWB IIA Petrol, 195? SI Petrol - all gone
    Outback Campers Sturt
    http://jandmf.com
    Narre Warren South
    I'd be more concerned about the ridge at the top as Powerband suggested. In the picture it looks like the unworn bore at the top is honed then there is a short section that is not honed because the honing tool is being supported by the ridge.
    Problem is how to remove the ridge. There is a tool for removing a wear ridge but it doesn't work on an 'F' head due to the angle of the top of the block.
    Cylinder Ridge Remover Standard T&E Tools 4289 New
    You used to be able to buy 'ridge dodger' top rings that had a step in them so that they didn't hit the ridge. On the badly worn motor in an Austin Somerset years back I fitted NOS pistons and left the top rings out (yes I know, a bodge, but it worked for about a year till I sold it).
    On my 6-cylinder Land Rover motor, also an 'F' head, I hand scraped the wear ridge to remove it. I also borrowed a bore comparator to measure the bore and found that it was just in tolerance.
    Engineers & Bearing Scrapers – General Tools
    You could re-assemble with new rings and there is no problem but if over revved you might end up with top rings broken.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Jan 2017
    Many thanks for the terrific advice, gentlemen. As cylinder #1 has the wear banding at the top of the stroke, and had the broken top ring, then I will focus on removing that as a priory.
    It was a great relief to read so much helpful advice and now I will tackle the tasks ahead with enthusiasm rather than dread.
    Many thanks and have a great weekend.
    Jeff
