Can't help, but the following instructions are from the workshop manual, but they relate to removing/replacing the Hood Latch Panel:
15. Adjust both of the hood latches.Loosen the 4 hood latch Torx bolts.Lower the hood and check for alignment.Open the hood and tighten the Torx bolts to 10 Nm(7 lb.ft).Check for the correct operation of the hood safety catch.If necessary, repeat the above adjustment procedure.
16. Connect the battery ground cable.
				2013 D4 expedition equipped
1966 Army workshop trailer
