 Originally Posted by
Ferret
				From my experience. A long way, 5k or more maybe but your mileage might vary.
But gee - easy enough to take off a wheel and check how much meat is left on the pad. Be aware there are only 2 sensors one on one of the front wheels and one on one of the rear wheels. Forget which wheels specifically have the sensors so you really need to to check all pad thickness anyway in case there is uneven wear.
Also would add the sensors have been known to activate just by sticks / stones etc flying up and damaging the sensors. And if the rear has been recently replaced then I would suspect a loose connection. Another reason to physically check the pads and the sensors.
 Don’t stress. If the only issue is in fact a properly triggered wear sensor you can drive as said 5000k plus.  But agree with all above. Have a look at each side for pad wear. Rear sensor is drivers side Inside pad and front is passenger inside pad. Out of the 8 pads only two actually can trigger the sensor. We drove to the cape and back after it triggered near Coen. Downside is you’ll be looking at that warning on the dash till you get is sorted and that means a new sensor. I believe you can snip and join The thin wires in the sensor cable and that will clear the warning but not fix the issue  Upside is it won’t put you in limp mode surprisingly. Stopping mustn't be considered a safety issue
Steve
				2014 white TDV6, compomotives with BFG KO2, E-Diff, rocksliders, Redarc DBS, Mitch Hitch, TPMS, icom UHF, GOE compressor and bash plates, hidden winch Mount, GAP ID tool.
