Looks like the fuel return line to me.
Edit...google LR029948
Hi Gents
Can someone identify the T piece circled pls. I may have a small crack on the underside. Is it an oil line to the injectors?
Thx Ezy
1964, S2a SWB "Ralph"
1977, S3 SWB "Smeg" (Gone)
1996 D1 300tdi auto (Gone)
1973 Rangie Classic (Gone)
2012, 110 (Series 12) Puma "The Tardis"
1962 109" Tray Back "Ernie"
1998 D1 300tdi (Dizzy)
2017 Kawasaki Versys 1000
You must now cut down the tallest tree in the forest... With... A HERRING!!!!!
Fuel return, it'll get worse if it has cracked, the vibrations will not help. They fairly pour out if it breaks, enough to cause a spontaneous combustion
Temporary fix
Taking the manifold off for a crack is a real pain....almost as bad as taking the engine out...as you need to remove all the cooling system plumbing.
Lucky you could get to the crack and seal it up, BTW the sealer is a combination of super glue and bicarb of soda, which creates a real hard type of plastic.
So there is no need to buy the expensive kits if you are happy with a white coloured seal.
Also if you intend to replace the manifold they are way cheaper buying one from Ford Spares than LR.
